[Qgis-developer] Problems building for QT5
G. Allegri
giohappy at gmail.com
Mon May 4 00:32:31 PDT 2015
Thanks Matthias.
2015-05-04 9:28 GMT+02:00 Matthias Kuhn <matthias at opengis.ch>:
> Hi Giovanni,
> There are two possibilities
> * PyQt4 with Qt5
> * PyQt5 with Qt5
> Neither of them are tested with QGIS. At the time I ported the code they
> were not available for my distro and I didn't compile them myself.
> I assume PyQt4/Qt5 should work pretty smooth but if a distro drops Qt5
> support it will likely switch to PyQt5 as well. So this option will
> probably only be used on isolated platforms for testing.
> PyQt5 will require some changes (foremost let cmake find the lib) but
> the real challenge will be to update plugins themselves.
> Matthias
> On 05/04/2015 09:15 AM, G. Allegri wrote:
>> Hi Jurgen,
>> will the switch to Qt5 require adapting the Python bindings?
>> giovanni
>> 2015-05-04 9:12 GMT+02:00 Jürgen E. <jef at norbit.de>:
>>> Hi Alessandro,
>>> On Mon, 04. May 2015 at 09:02:39 +0200, Alessandro Pasotti wrote:
>>>> I set QT5 ON and I think I've installed all requirements (I'm on Ubuntu
>>>> 14.04) but I get lot of errors while building.
>>>> Here is the output:
>>>> https://dpaste.de/dJNO
>>>> It seems like it still links to Qt4, any hint?
>>> Try WITH_BINDINGS FALSE
>>> Jürgen
>>> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
>>> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
>>> Software Engineer D-26506 Norden http://www.norbit.de
>>> QGIS release manager (PSC) Germany IRC: jef on FreeNode
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Giovanni Allegri
http://about.me/giovanniallegri
Gis3W - http://gis3w.it
Ikare - http://ikare.it
Twitter: https://twitter.com/_giohappy_
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
