[Qgis-developer] How to set the PyQGIS environnement on Windows	properly?
    Nathan Woodrow
    madmanwoo at gmail.com
    Tue May  5 15:16:53 PDT 2015
Hey,
This is what I use for everything that I have setup:
@ECHO OFF
REM
REM Change %OSGEO4W_ROOT% in setenv.bat to change in the location of QGIS.
REM
for %%x in (%cmdcmdline%) do if /i "%%~x"=="/c" set DOUBLECLICKED=1
REM Change OSGeo4W_ROOT to point to your install of QGIS.
SET OSGEO4W_ROOT=C:\OSGeo4W
SET QGISNAME=qgis
SET QGIS=%OSGEO4W_ROOT%\apps\%QGISNAME%
set QGIS_PREFIX_PATH=%QGIS%
CALL %OSGEO4W_ROOT%\bin\o4w_env.bat
: Python Setup
set PATH=%OSGEO4W_ROOT%\bin;%QGIS%\bin;%PATH%
SET PYTHONHOME=%OSGEO4W_ROOT%\apps\Python27
set PYTHONPATH=%QGIS%\python;%PYTHONPATH%
ECHO OSGeo path is: %OSGEO4W_ROOT%
ECHO Getting QGIS libs from: %QGIS%
ECHO Python loaded from: %PYTHONHOME%
Then you can add what you need at the end.  For a simple test just drop to
Python and try the import.
- Nathan
On Wed, 6 May 2015 at 07:42 Florin-Daniel Cioloboc <
cioloboc.florin at gmail.com> wrote:
> Hello everyone,
> I'm having problems with a specific error, which is pretty common from
> what I can see but can't seem to find a solution.
> When I try to import the qgis module the following error occurs:
> ImportError: No module named 'qgis'
> So far this is the guide <http://planet.qgis.org/planet/user/3/> I'm
> using and here's the settings for the .cmd, I'm assuming it has something
> to do with this:
>> @echo off
>> SET OSGEO4W_ROOT=D:\OSGeo4W64
>> call "%OSGEO4W_ROOT%"\bin\o4w_env.bat
>> call "%OSGEO4W_ROOT%"\apps\grass\grass-6.4.3\etc\env.bat at echo off
>> path %PATH%;%OSGEO4W_ROOT%\apps\qgis\bin
>> path %PATH%;%OSGEO4W_ROOT%\apps\grass\grass-6.4.3\lib
>> set PYTHONPATH=%PYTHONPATH%;%OSGEO4W_ROOT%\apps\qgis\python;
>> set PYTHONPATH=%PYTHONPATH%;%OSGEO4W_ROOT%\apps\Python27\Lib\site-packages
>> set QGIS_PREFIX_PATH=%OSGEO4W_ROOT%\apps\qgis
>> set PATH=C:\Program Files (x86)\JetBrains\PyCharm Community Edition 4.0.6\bin\pycharm.exe;%PATH%
>> cd %HOMEPATH%\TER\development
>> start "PyCharm aware of Quantum GIS" /B "C:\Program Files (x86)\JetBrains\PyCharm Community Edition 4.0.6\bin\pycharm.exe" %*
>> I realize this is quite a beginner's question but in any case I could use
> some help.
> Best wishes
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150505/c34b0d1f/attachment.html>
