[Qgis-developer] Problems building for QT5
Jürgen E. Fischer jef at norbit.de
Wed May 6 06:57:16 PDT 2015
Hi Alessandro,
On Wed, 06. May 2015 at 10:54:19 +0200, Alessandro Pasotti wrote:
> This runs fine from the build directory:
> LD_LIBRARY_PATH=output/lib/ output/bin/qgis
> It seems like the install process (make install) removes the runtime path
> from the .so and this causes the problem: running ldd in output/lib/
> doesn't show any Qt 4 lib while running ldd on the installed libqgis_gui.so
> shows libQtCore.so.4 libQtGui.so.4 etc.
hm, why would a libqgis_gui.so suddenly start to point at libQtCore.so when the
Qt5 version it's linked against is named libQt5Core.so?  Are you sure the
libqgis_gui.so is the shared library you installed and not a previous ony built
with Qt4?
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150506/eef4e74c/attachment.pgp>
