[Qgis-developer] Processing and ftools (Proposal for hackfest)
Giovanni Manghi giovanni.manghi at gmail.com
Thu May 7 02:24:07 PDT 2015
> Also, many ftools algorithms are terribly slow (e.g. dissolve), particularly
> when compared to the equivalent tools based on ogr2ogr, that Giovanni Manghi
> added to Processing a few months ago. It may worth considering the
> possibility of deleting some ftools algorithm in favor of the ogr2ogr based
> algorithms.
I will try to add as many geoprocessing operations based on
ogr2ogr/sql as I can,
especialy the ones that are really slow in ftools. Anyway to be able
to add the operations
that involve more than 1 input layer it will be needed to add a method
in processing to
create (on the fly) virtual vectors (and in general this tool would
benefit from other improvements
like multi-attribute selection). I plan to discussa about this things
in Denmark.
cheers
Giovanni Manghi
http://naturalgis.pt/
giovanni.manghi at naturalgis.pt
* WebGIS development
* QGIS/PostGIS Training
* QGIS Support and Consulting
* QGIS development
Google+/Hangouts: giovanni.manghi at gmail.com
Giovanni is QGIS main tester and active member of its development team
