[Qgis-developer] shp cannot be styled
Raymond Nijssen
r.nijssen at terglobo.nl
Thu May 7 10:03:40 PDT 2015
Hi Paolo,
Exact same problem here (QGIS testing on linux) and also solved after a
"save as shapefile".
Regards,
Raymond
On 07-05-15 18:52, Paolo Cavallini wrote:
> Hi all.
> This file:
> http://www.faunalia.eu/~paolo/qgis/result.zip
> resulting from
> processing.runalg("saga:gridstatisticsforpolygons","/tmp/RESULT.tif","/path/municipalities.shp",False,False,True,False,True,False,False,False,0,None)
> seems impossible to thematize on the basis of the ``Calculated`` column.
> If saved as a new shapefile, it is OK. Possibly SAGA produces a wrong
> dbf? Anyone confirms?
> Thanks.
Terglobo
Ampèrestraat 110
5223 CT 's-Hertogenbosch
06-25314983
