[Qgis-developer] Rendering active map symbol as QPixmap
Nathan Woodrow
madmanwoo at gmail.com
Thu May 7 15:34:03 PDT 2015
Hey Andrew,
This is how I did it with Roam to get all the legend items for the layer:
items = layer.rendererV2().legendSymbologyItems(ICON_SIZE)
That will give you a list of:Text - Icon pairs
if you are using the rule base renderer you get can the symbol for the rule
and paint that into a pixmap, however note that one feature can have many
symbols so you will have to use the method that returns a list for all the
symbols.
Depending on what you are doing legendSymbologyItems might give you what
you need without extra work.
- Nathan
On Fri, 8 May 2015 at 07:00 Andrew McClure <andrew at southweb.co.nz> wrote:
> Any takers for this one? I'd like to render the active symbol for a layer
> as a QPixmap in a dialog.
> I have got this far:
> s = layer().rendererV2()
> key = s.rootRule().findRuleByKey(s.rootRule().ruleKey())
> This tells me the active rule key to be rendered but how to get the image
> data?
> Perhaps I am barking up the wrong tree here?
> Thanks
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150507/db000b79/attachment.html>
