[Qgis-developer] Debugging a QGIS crash
Andrew McClure
andrew at southweb.co.nz
Sat May 9 01:56:18 PDT 2015
Tom
I'd suggest installing VM Ware and running QGIS under Ubuntu. You will have access to a console and better debugging facilities. You could even run the program under strace. Ideally you want to see a stack trace so you can identify the pyqt commands that were executed prior to crashing.
Of course it could be operating system specific. For windows, a quick google revealed this:
http://stackoverflow.com/questions/112831/how-to-get-a-stack-trace-when-c-program-crashes-using-msvc8-2005
