[Qgis-developer] Processing: Create points along lines fails
Giovanni Manghi
giovanni.manghi at gmail.com
Thu May 14 10:56:32 PDT 2015
> With the similar command from GDAL backend
> processing.runalg("gdalogr:createpointsalonglines","/home/paolo/fiumi.shp","geometry",0.5,"",None)
> I get:
> GDAL execution console output
> layer names ignored in combination with -sql.
this is a warning and can be ignored
> Segmentation fault
this is not processing (or the specific tool) issue. Lately on Linux I
have seen many gdal tools seg fault (from the command line).
