[Qgis-developer] QGIS to ArcGIS Map Package
Stefan Keller sfkeller at gmail.com
Sat May 16 06:34:35 PDT 2015
Hi
"Map packages include a map document (.mxd) and the data referenced by
the map layers packaged into one portable file."
It's about sharing ArcGIS data with styling.
So, there are two parts: 1. a prorietary data format and 2. a
prorietary styling.
Actually, we've proposed a similar thing for QGIS called "QGIS
All-in-one Project" and began to implement a plugin [1].
It's well-defined and based on open formats.
So, how about paying a programmer to 1. enhance the QGIS All-in-one
Project plugin and 2. asking Esri if they could implement an import
for this :-)
Yours, Stefan
[1] http://giswiki.hsr.ch/QGIS_All-in-one_Project_Plugin
2015-05-16 13:26 GMT+02:00 Zoltan <zoltans at geograph.co.za>:
> This:
> http://www.esri.com/news/arcuser/0911/share-and-document-maps-with-map-packages.html
> http://www.esri.com/news/arcuser/0911/files/mapackages.pdf
> http://blogs.esri.com/esri/arcgis/2010/09/30/map-packages-con-t/
> http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/An_overview_of_the_Package_toolset/0017000000q6000000/
> Regards,
> Zoltan
> On 16/05/2015 13:24, Roy wrote:
> Hi,
> what do you mean with "Map Package" ?
> Il 15/05/2015 16:08, Zoltan Szecsei ha scritto:
> Hi,
> Once I have created a map in the print composer, is there a way to export it
> to "Map Package"?
> Thanks & regards,
> Zoltan
> Qgis-developer mailing list
