[Qgis-developer] saveAs crash on Squeeze/testing
Richard Duivenvoorde rdmailings at duif.net
Sun May 17 09:31:56 PDT 2015
Running/building Master here on Debian testing.
Segfault when after loading a shapefile use 'saveAs' menu:
When running in gdb, it looks like something is wrong outside of QGIS:
maybe gdal/proj/spatialite? Others running Debian see this?
(gdb) bt
#0  0x00007fffefcbeff4 in spatialite_init () from
/usr/lib/x86_64-linux-gnu/libspatialite.so.5
#1  0x00007ffff4dab4bf in ?? () from /usr/lib/libgdal.so.1
#2  0x00007ffff4db0385 in ?? () from /usr/lib/libgdal.so.1
#3  0x00007ffff4db40a6 in ?? () from /usr/lib/libgdal.so.1
#4  0x00007ffff4da1d72 in OGR_Dr_CreateDataSource () from
#5  0x00007ffff40c4640 in QgsVectorFileWriter::ogrDriverList () at
/home/richard/dev/qgis/git/qgis/src/core/qgsvectorfilewriter.cpp:2143
#6  0x00000000009085de in QgsVectorLayerSaveAsDialog::setup
(this=0x13b2290) at
/home/richard/dev/qgis/git/qgis/src/app/ogr/qgsvectorlayersaveasdialog.cpp:59
#7  0x00000000009083f1 in
QgsVectorLayerSaveAsDialog::QgsVectorLayerSaveAsDialog (this=0x13b2290,
srsid=2517, layerExtent=..., layerHasSelectedFeatures=false,
    options=-1, parent=0x118e290, fl=...) at
/home/richard/dev/qgis/git/qgis/src/app/ogr/qgsvectorlayersaveasdialog.cpp:40
#8  0x000000000059eb0a in QgisApp::saveAsVectorFileGeneral
(this=0x118e290, vlayer=0x8baf120, symbologyOption=true)
    at /home/richard/dev/qgis/git/qgis/src/app/qgisapp.cpp:5228
#9  0x000000000059e6c0 in QgisApp::saveAsFile (this=0x118e290) at
/home/richard/dev/qgis/git/qgis/src/app/qgisapp.cpp:5190
#10 0x000000000095149c in QgisApp::qt_static_metacall (_o=0x118e290,
_c=QMetaObject::InvokeMetaMethod, _id=276, _a=0x7fffffffb5f0)
    at /home/richard/dev/qgis/git/qgis/build/src/app/moc_qgisapp.cxx:906
#11 0x00007ffff228e85c in QMetaObject::activate(QObject*, QMetaObject
const*, int, void**) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#12 0x00007ffff15bf012 in QAction::triggered(bool) () from
/usr/lib/x86_64-linux-gnu/libQtGui.so.4
#13 0x00007ffff15c0b97 in QAction::activate(QAction::ActionEvent) ()
from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
Regards,
