[Qgis-developer] QGIS CRS handling question
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Sat May 23 03:24:03 PDT 2015
As a continuation of my first answer to question 2: You might simply
delete the epgs:3006 definition from your QGIS srs.db database.
Its a sqlite database residing in directory ..\resources.
Open the database with a sqlite manager and in table "tbl_srs" delete
the row with column "auth_id" = 3006. It's possible there exists other
EPSG defintions with the same projection parameters as EPSG:25833, so
you might have to repeat the deletion with another values for auth_id
(Actually, I don't know what will happen in QGIS afterwards, so be sure
to make a copy of the file srs.db for security reasons beforehand ;-)
Regards
Bo Victor Thomsen
AestasGIS
Denmark
On 22-05-2015 09:42, Otto Dassau wrote:
> Hi,
> I would like to understand QGIS behavior a little better for CRS handling.
> I have a tif/tfw file (input.tif) and would like to create compressed geotiff
> tiles from it (output.tif).
> 1) When I use
> gdal_translate -co COMPRESS=JPEG -co PHOTOMETRIC=YCBCR -co TILED=YES \
>   -a_srs EPSG:25833 input.tif output.tif
> gdalinfo shows:
> Driver: GTiff/GeoTIFF
> Files: output.tif
> Size is 16100, 15300
> Coordinate System is:
> LOCAL_CS["ETRS89 / UTM zone 33N",
>      GEOGCS["ETRS89",
>          DATUM["unknown",
>              SPHEROID["unretrievable - using WGS84",6378137,298.257223563],
>              TOWGS84[0,0,0,0,0,0,0]],
>          PRIMEM["Greenwich",0],
>          UNIT["degree",0.0174532925199433]],
>      AUTHORITY["EPSG","25833"],
>      UNIT["metre",1]]
> loading this file in QGIS I am asked to provide the CRS for the layer,
> although it should be written in the GeoTiff header.
> 2) When I use
>   -a_srs "+proj=utm +zone=33 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m \
>   +no_defs" input.tif output.tif
> gdalinfo shows:
> Files: output.tif
> PROJCS["UTM Zone 33, Northern Hemisphere",
>      GEOGCS["GRS 1980(IUGG, 1980)",
>          DATUM["unknown",
>              SPHEROID["GRS80",6378137,298.257222101],
>      PROJECTION["Transverse_Mercator"],
>      PARAMETER["latitude_of_origin",0],
>      PARAMETER["central_meridian",15],
>      PARAMETER["scale_factor",0.9996],
>      PARAMETER["false_easting",500000],
>      PARAMETER["false_northing",0],
>      UNIT["metre",1,
>          AUTHORITY["EPSG","9001"]]]
> loading this file in QGIS, I am *not* asked to provide the CRS for the
> layer, but QGIS assigns the wrong CRS. In my case I want EPSG 25833 but get
> EPSG 3006 (which has the same parameters as 25833, but is not what I want).
> How can I make QGIS read the CRS correctly? Does anybody has a solution for
> this?
> Thanks a lot
> Otto
> Qgis-developer mailing list
