[Qgis-developer] New geometry classes merged
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Mon May 25 01:45:21 PDT 2015
Hi devs
Finally, the new geometry classes are merged to master branch (the new
classes are under src/core/geometry). The changes contain only the core
classes, not included are the changes in the rendering workflow and all
the edit tools. They would be too risky for 2.10 and will be merged at a
later time (most likely for 2.12).
At the moment, the compatibility class QgsGeometry should hide the
differences to the old geometry. In practice, there will be a number of
unexpected problems after the merge. If you encounter one, fill a ticket
in the tracker and assign it to me (or drop a note to the devel list).
My apologies beforehand for the trouble caused.
There are a number of provider unit tests not passing at the moment
(mostly because of wkt formating issues). I'll go through them in the
next days.
Regards,
Marco
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
