[Qgis-developer] qgis master dev: postgis changeAttributeValue error
Matthias Kuhn
matthias at opengis.ch
Wed May 27 08:48:15 PDT 2015
Hi Marco
Are you sure that you are testing the same thing.
IIRC there are the following methods which can be easily mixed up:
layer.changeAttributeValue()
and
layer.provider().changeAttributeValues()
Best,
Matthias
On 05/27/2015 11:02 AM, marco bra wrote:
> Accessing same postgresql/postgis db
> and using plugin QuickMultiAttributeEdit
> 1) all works fine on qgis 2.8.1
> 2) using 2.9.0-Master Master, exported
> qgis master dev (next 2.9)
> i get
> Traceback (most recent call last):
> File
> "/home/ubuntu/.qgis2/python/plugins/QuickMultiAttributeEdit/quickmultiattributeedit_dialogs.py",
> line 121, in run
> layer.dataProvider().changeAttributeValue(feature.id
> <http://feature.id>(),nPosField,value)
> AttributeError: 'QgsVectorDataProvider' object has no attribute
> 'changeAttributeValue'
> The source plugin rows are:
> 120. for feature in oFeaIterator:
> 121.
> There is some changed or can be a bug ?
> Thank you
> Marco
> Linux Infinite Freedom
> I'm writing from this place:
> http://www.openstreetmap.org/?lat=44.39945&lon=8.6798&zoom=15&layers=M
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150527/95b78743/attachment-0001.html>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150527/95b78743/attachment-0001.pgp>
