[Qgis-developer] Changing folder of plugin install
Rémi Cura
remi.cura at gmail.com
Fri May 29 05:52:55 PDT 2015
Hey, thanks for the super-quick answer.
Can't we just change the plugin database for this plugin?
Surely there is a way to do it manually !
Or simply change the folder name on the server?
Deleting the plugin make it loose all the history, which I find quit bad.
Also, if the consequences are so dire, wouldn't is be necessary to check at
import that plugin name and folder name match?
Cheers,
Rémi-C
2015-05-29 13:55 GMT+02:00 Alessandro Pasotti <apasotti at gmail.com>:
> Hi,
> The only option I see is to delete the plugin that was created with a
> wrong package name and create a new one with the right package name.
> Plugin name and folder name must match.
> 2015-05-29 13:47 GMT+02:00 Rémi Cura <remi.cura at gmail.com>:
>> Hey,
>> we have a problem with our plugin
>> <http://plugins.qgis.org/plugins/interactive_map_tracking-master>,
>> QGIS gives a wrong error message at first install.
>> Apparently this is due to the fact that our plugin is in a folder called
>> 'interactive_map_tracking-master'
>> and the plugin name is 'interactive_map_tracking'
>> I tried to update the plugin by sending a new zip containing the correct
>> folder name, but it is blocked by the site
>> "Plugin name mismatch: the plugin main folder name in the compressed file
>> (interactive_map_tracking) is different from the original plugin package
>> name (interactive_map_tracking-master)."
>> I don't see any contact form on the plugin web site,
>> could somebody un-stuck us please?
>> Thanks,
>> Rémi-C
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150529/afb3eb80/attachment.html>
