[Qgis-developer] rendering tests, what's the latest approach ?
Sandro Santilli strk at keybit.net
Thu Nov 12 07:48:09 PST 2015
On Thu, Nov 12, 2015 at 04:42:07PM +0100, Matthias Kuhn wrote:
> Simple answer: don't use rendering tests and find other means to check
> it ;-)
How could I check that an arror is not flipped and does not move
to the other side of the line ?
To be honest, I like the idea of rendering tests. I know they are
fragile in their current incarnation, but being a graphical
application having tests actually check what the user would see
is a good way to catch many issues.
> If you still need, use the MultiRenderChecker, it is based on the
> RenderChecker but adds more possibilities for anomalies. At least that's
> the latest state of rendering tests I'm aware of...
Ok, great. How about the distinction between these two files ?
  * testqgsstylev2.cpp
  * testqgssymbolv2.cpp
Actually, the second one is _not_ in the 2.8 branch (which I'm
targetting). Should it be back-ported ?
--strk;
