[Qgis-developer] rendering tests, what's the latest approach ?
Nyall Dawson
nyall.dawson at gmail.com
Sat Nov 14 01:12:43 PST 2015
On 13 November 2015 at 02:42, Matthias Kuhn <matthias at opengis.ch> wrote:
> Simple answer: don't use rendering tests and find other means to check
> it ;-)
Hmm... for something like this (testing rendering of a line style), I
think a rendering test is perfectly acceptable! It's only when
rendering tests are used for things like checking geometry operations
that it's an issue IMO.
Nyall
> If you still need, use the MultiRenderChecker, it is based on the
> RenderChecker but adds more possibilities for anomalies. At least that's
> the latest state of rendering tests I'm aware of...
> Best
> On 11/12/2015 04:37 PM, Sandro Santilli wrote:
>> I've found a bug in rendering line-offsetted marker line symbols [1]
>> and wondering what's the currently recommended way to add a testcase.
>> [1] http://hub.qgis.org/issues/13811 or
>> https://github.com/qgis/QGIS/pull/2442
>> Looking around I see many test files using the QgsRenderChecker
>> class in tests/src/core but the rationale is not clear to me.
>> Here's the list:
>> regression992.cpp
>> testqgsblendmodes.cpp
>> testqgscomposerobject.cpp
>> testqgscomposerutils.cpp
>> testqgsdiagram.cpp
>> testqgsgeometry.cpp
>> testqgsgradients.cpp
>> testqgsimageoperation.cpp
>> testqgsinvertedpolygonrenderer.cpp
>> testqgslabelingenginev2.cpp
>> testqgslegendrenderer.cpp
>> testqgslinefillsymbol.cpp
>> testqgsmaprenderer.cpp
>> testqgsmaprotation.cpp
>> testqgspainteffect.cpp
>> testqgspointpatternfillsymbol.cpp
>> testqgsrasterfill.cpp
>> testqgsrasterlayer.cpp
>> * testqgsrenderers.cpp
>> testqgsshapeburst.cpp
>> Then other files use the QgsMultiRenderChecker class instead:
>> qgscompositionchecker.cpp
>> testqgsdiagram.cpp
>> * testqgsstylev2.cpp
>> * testqgssymbolv2.cpp
>> What's the difference between the two classes ? Which one should I use ?
>> Should I put the new case in any existing file ?
>> (I've tagged the possible candidates with a star)
>> --strk;
>> () Free GIS & Flash consultant/developer
>> /\ http://strk.keybit.net/services.html
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Matthias Kuhn
> OPENGIS.ch - https://www.opengis.ch
> Spatial • (Q)GIS • PostGIS • Open Source
