[Qgis-developer] problem with GRASS 7 when creation a new mapset
matteo matteo.ghetta at gmail.com
Sun Nov 15 08:51:55 PST 2015
Hi Radim,
sorry, but I found some time only now for testing your suggestions..
Briefly: I didn't compiled GRASS, so it is in the folder /usr/bin/grass70
then I tried to add in the bash script the LD_LIBRARY_PATH for GRASS as
follows:
export
GRASS_INSTALL_PREFIX="/home/ma7730/lavori/QGIS/QGIS-Master/buildM/src/plugins/grass/7"
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$GRASS_INSTALL_PREFIX
but I'm always getting the same error when trying to create a new mapset:
Impossibile aprire il mapset. Blocco dei mapset fallito (exitStatus=0,
exitCode=127, errorCode=5, error=Unknown error stdout=,
stderr=/usr/lib/grass70/etc/lock: error while loading shared libraries:
libgrass_gis.7.0.1.so: cannot open shared object file: No such file or
directory
Don't know how to handle this error and how to configure your GRASS
plugin..
Sorry for the noise..
Thanks
Matteo
