[Qgis-developer] drill down in QgsValueRelationWidgetWrapper::createCache
Nyall Dawson
nyall.dawson at gmail.com
Tue Nov 17 11:19:32 PST 2015
On 17 Nov 2015 10:56 PM, "Alessandro Pasotti" <apasotti at gmail.com> wrote:
> Hi,
> it seems that the widget's expression context does not have access to the
currently edited record.
> Maybe I've just not found a way to do that but it's impossible to filter
relations with an expression built upon the the values of the "main" record
(the one currently edited in the form) because $currentfeature refers to
the relation layer,
> A possible solution would be to add a $currentformfeature to the
expression and add the edited feature to the expression context.
> Would it be a possible solution?
> Any hint?
I can't find the original discussion this relates too... What's the issue
you're trying to solve?
Nyall
> Alessandro Pasotti
> w3: www.itopen.it
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151118/2c9146ca/attachment.html>
