[Qgis-developer] problem with GRASS 7 when creation a new mapset
matteo matteo.ghetta at gmail.com
Wed Nov 18 05:24:56 PST 2015
Hi Radim,
> Missing is the path to GRASS libs, try
> export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/bin/grass70/lib/
> check also if /usr/bin/grass70/lib/libgrass_gis.7.0.1.so exists.
finally it seems working now.. the problem was (beside my ignorance.. :)
) that executable of grass are here:
/usr/bin/grass70
while hte libraries are here:
/usr/lib/grass70/lib
adding
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/lib/grass70/lib/
solves the problem!
Thanks!
Matteo
