[Qgis-developer] QgsComposerMap zoomToExtent problem
James Stott
jamesstott1 at gmail.com
Sun Nov 22 11:23:53 PST 2015
I have a QgsComposerMap that I want to zoom to the extent of a feature in a
vector layer.
geomBBRect = geometry.boundingBox()
myComposerMap.zoomToExtent(geomBBRect)
I am trying to use zoomToExtent to make the map show the correct area.
However, I get a blank map when I run my code. If I check what the current
scale is, its returned as 'nan'.
I tried using setNewExtent() before, but this alters the size of my
QgsComposerMap. I want to keep the same map size each time.
After doing a little bit of checking, it seems that:
myComposerMap.currentMapExtent().xMinimum()))
myComposerMap.currentMapExtent().xMaximum()))
both return 'nan' but yMinimum and yMaximum return coordinates.
I can not figure out why. Can anyone help shed any light on the problem? I
can provide more code if needed.
James
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151122/0364ec41/attachment.html>
