[Qgis-developer] Tool to pick up linear referencing measure from mouse
Nyall Dawson
nyall.dawson at gmail.com
Tue Nov 24 10:50:08 PST 2015
On 25 Nov 2015 1:39 AM, "Radim Blazek" <radim.blazek at gmail.com> wrote:
> On Mon, Nov 23, 2015 at 6:00 PM, Régis Haubourg
> <regis.haubourg at eau-adour-garonne.fr> wrote:
> > Hi,
> > I'm having a classical use case here. Before starting a new plugin, and
> > since it is a very common task in GIS, I would like to know if anyone
has
> > made something alike:
> > - I have a postgis db with LINESTRINGM routes (watercourses already
> > calibrated with measures).
> > - I have a non geometric table registering events with start and end
> > measures + identifier of my routes (watercours ID).
> > - I create my event in the attribute table, with one ID and two manually
> > typed measures, then a view cast it to spatial view using
> > locate_beetween_measure function.
> > I would like to create a form with two tools dedicated to "pick up" my
route
> > and the measure. i've done it in Arcview 3.2 once in the old past..
> > What could be the current better and simpler approach in QGIS?
> I think that now (>=2.8), when QGIS geometry supports M (measure), the
> measure calculated for the nearest point on the identified line
> could/should be added to derived attributes in standard identify
> results.
And as of 2 days ago, it does: ;)
https://github.com/qgis/QGIS/commit/1f0d24a0c7a6555ced117ecfc08a73afb1f31b46
Nyall
> > LRS plugin does not have that feature, and requires to recalibrate
layers
> > from scratch.
> Similarly Locate, Create events and Calculate measures tools in the
> LRS plugin should be extended to support existing layers with
> measure.
> Radim
> > Could we dream for the future of a new generic form widget with custom
> > expressions to get attributes or geometric information from a layer
(with
> > snapping options )?
> > Cheers
> > Régis
> > View this message in context:
http://osgeo-org.1560.x6.nabble.com/Tool-to-pick-up-linear-referencing-measure-from-mouse-tp5238110.html
> > Sent from the Quantum GIS - Developer mailing list archive at
Nabble.com.
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151125/757bed6b/attachment.html>
