[Qgis-developer] grass module don't appear
Radim Blazek
radim.blazek at gmail.com
Thu Nov 26 00:40:30 PST 2015
On Wed, Nov 25, 2015 at 9:35 PM, Giovanni Manghi
<giovanni.manghi at gmail.com> wrote:
>> Then I searched for r.mapcalculator, which was present in the old processing toolbox. I didn't find it
>> in the grass7 processing modules list. Although the grass7 stand alone has r.mapcalc (not r.mapcalculator),
>> in the grass7 processing toolbox neither r.mapcalculator nor r.mapcalc are present.
>> I wonder if is it possible to add grass7 module thus I can insert r.null, then I would like to know if
>> I can put in r.mapcalculator or r.mapcalc at least.
> In Processing GRASS r.mapcalc can't be added, unless doing some work, see
> http://hub.qgis.org/issues/6894
> on the other hand in GRASS 7 r.mapcalculator is not available, so it
> is not also in Processing.
Just a note, r.mapcalc including visual editor is present in the GRASS Plugin
http://www.gissula.eu/qgis-grass-plugin-crowdfunding/images/r.mapcalc.png
Radim
