[Qgis-developer] Processing scripts in stand-alone Python scripts
Victor Olaya
volayaf at gmail.com
Mon Nov 30 08:16:25 PST 2015
The issue is that the "default" folder is based on the location of the
parent app (if I am not wrong). I can probably move it to somewhere in
.qgis2 instead. But if there is a manually entered path, then it will
not use the default one, that's only used if no custom configuration
has been done.
Let me check and will see how to fix this.
2015-11-30 15:23 GMT+01:00 Anita Graser <anitagraser at gmx.at>:
> On Fri, Nov 27, 2015 at 3:53 PM, Anita Graser <anitagraser at gmx.at> wrote:
>> On Fri, Nov 27, 2015 at 8:58 AM, Victor Olaya <volayaf at gmail.com> wrote:
>>> I think this must be related to the configuration of the plugins folder.
>>> The script provider reads scripts in the scripts folder, which is
>>> configured as an option. Maybe that setting is not available in your
>>> stand-alone script...since it is stored using QSettings. You can check
>>> it calling ScriptUtils.scriptsFolder()
>> from processing.script.ScriptUtils import *
>> print ScriptUtils.scriptsFolder()
>> if run in stand-alone, returns a wrong folder:
>> /home/agraser/temp/standaloneprocessing/processing/scripts
>> (/home/agraser/temp/standaloneprocessing is the location of my stand-alone
>> script)
>> instead of the correct folder in the QGIS console: u'
>> /home/agraser/.qgis2/processing/scripts'.
>> Seems like we are getting closer to where the real issue is hiding. Imho
>> it makes little sense that the paths appear relative to the stand-alone
>> script's location.
> If I move the stand-alone script into
> /home/agraser/.qgis2/, I can execute it and it finds my custom Processing
> script.
> In any other location the script fails because Processing uses the wrong
> scripts folder.
> I'd rather not hard-code the scripts folder. Do you have an idea how to make
> Processing use its "default" scripts folder rather than something in the
> stand-alone script's location?
> Thanks and best wishes,
> Anita
