[Qgis-developer] [[ImportError]]: dynamic module does not define init function (initcore)
Matthias Kuhn matthias at opengis.ch
Mon Nov 30 11:59:06 PST 2015
Hi Martin
Can you `touch python/core/core.sip` or start with a clean build dir?
Sometimes an error happens when building the python bindings and when
compiling again the build system spuriously assumes that python bindings
have been built correctly and skips rebuilding them despite them not
actually being built.
Matthias
On 11/30/2015 08:48 PM, Martin Landa wrote:
> 2015-11-30 20:40 GMT+01:00 Martin Landa <landa.martin at gmail.com>:
>>> which has been correctly detected. I can import `qgis.core` from
>>> Python interpreter, QGIS shows "[[ImportError]]: dynamic module does
>>> not define init function (initcore)".
> ok, built so libs seems to be empty:
> nm /usr/local/share/qgis/python/qgis/_core.so | grep Qgs -c
> 0
> Ma
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial • (Q)GIS • PostGIS • Open Source
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151130/210eeb52/attachment.sig>
