[Qgis-developer] TypeError: C++ type 'QgsFeatureIds' is not supported as a signal argument type
//./\\-/_.\\
m431m at tutanota.com
Thu Oct 1 07:22:27 PDT 2015
No Mac user able to reproduce the error? Am i the only one?
m431m
25. Sep 2015 13:50 de m431m at tutanota.com:
> > Hi QGIS developers!
> I got strange error with the 'commitedFeaturesRemoved' signal.
> See: >
> http://www.qgis.org/api/classQgsVectorLayer.html#a520550b45603ed20d593b1050768bd97
> I try on python console (with any active layer on editing mode):
> >>> layer = iface.activeLayer()
> >>> def listener(s, l):
> >>> print s, l
> >>> layer.committedFeaturesRemoved.connect(listener)
> It returns `TypeError: C++ type 'QgsFeatureIds' is not supported as a
> signal argument type`
> Now replace `layer.commitedFeaturesRemoved.connect(listener)`by:
> >>> from PyQt4.QtCore import QObject
> >>> from PyQt4.QtCore import SIGNAL
> >>> QObject.disconnect(layer, SIGNAL(r"committedFeaturesRemoved()"),
> listener)
> No error, but it returns `False`.
> If I delete some features and switch off editing mode, it returns nothing!
> No print! The signal doesn't work(?)
> After exchanging a few message with some people on irc #qgis, the error
> only appears with latest QGIS version on OSX10.10.5. (it works well with
> 2.8.2).
> Maybe someone that has approached the same problem... and solved it?
> m431m
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151001/258b3963/attachment.html>
