[Qgis-developer] New plugin Dynamic Layers - Change layers datasource with variables
kimaidou kimaidou at gmail.com
Tue Oct 6 08:06:13 PDT 2015
And a new video showing how to use a vector layer as a data source for
variables
https://vimeo.com/141546964
Cheers,
Michaël
2015-10-06 16:40 GMT+02:00 kimaidou <kimaidou at gmail.com>:
> Hi all,
> I have just released the plugin Dynamic Layers which let you
> * configure a "dynamic datasource" for any layer with variables. You can
> use a syntax like {$myvar}
> * Configure a table of variable values to use as replacements
> * Use a vector layer as a source for this variables ( fields name must
> correspond to variable names
> * Define a layer as "extent layer" on which to zoom to full extent when
> aplying variables
> Then you can apply the variables on the configured layers to see the
> changes in you project, and save the project if you want.
> Use cases :
> * You have some PostGIS layers with subqueries such as
> table=(SELECT * FROM mytable WHERE country = 'France')
> and you have data for the whole world. You can use the plugin to configure
> a datasource such as
> table=(SELECT * FROM mytable WHERE country = '{$COUNTRY}')
> And then set the variable COUNTRY to 'Spain' or wichever country.
> You can also change the path to shapefiles, such as
> "/my/folder/mydata_{$COUNTRY}.shp"
> A video is sometimes better than a description :
> https://vimeo.com/141541813
> Source code here:
> Documentation in progress...
> Any feedback welcome
> Regards
> Michaël
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151006/8fa57ff2/attachment.html>
