[Qgis-developer] Importing a Python module for reading HDF5
Radosław Pasiok
rpasiok at gmail.com
Tue Oct 6 11:30:51 PDT 2015
Hello Devs!
I would like to kindly ask for help in importing any Python module for
reading HDF5 files on 64bit QGIS in Windows (OSGeo4W distribution).
I tried to use *h5py* and *pytables* binaries from [1]. There is no problem
with importing the modules in a Python session run from OSGeo Shell:
Python 2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500 64 bit (AMD64)]
on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> import h5py
>>> import tables
But in the QGIS Python console:
>>> import h5py
File "<input>", line 1, in <module>
File "C:/OSGEO4~2/apps/qgis-ltr/./python\qgis\utils.py", line 478, in
_import
mod = _builtin_import(name, globals, locals, fromlist, level)
File "C:\OSGEO4~2\apps\Python27\lib\site-packages\h5py\__init__.py", line
23, in <module>
from . import _conv
_import
File "h5py\h5r.pxd", line 21, in init h5py._conv
(D:\Build\h5py\h5py-2.5.x\h5py\_conv.c:6975)
_import
File "h5py\_objects.pxd", line 12, in init h5py.h5r
(D:\Build\h5py\h5py-2.5.x\h5py\h5r.c:2885)
_import
File "h5py\_objects.pyx", line 1, in init h5py._objects
(D:\Build\h5py\h5py-2.5.x\h5py\_objects.c:6993)
_import
ImportError: DLL load failed: Nie mo¿na odnaleæ okrelonej procedury.
>>> import tables
_import
File "C:\OSGEO4~2\apps\Python27\lib\site-packages\tables\__init__.py",
line 85, in <module>
from tables.utilsextension import (
_import
>>> import tables
_import
_import
>>> import h5py
_import
13, in <module>
from . import _errors
ImportError: cannot import name _errors
>>> import h5py
_import
13, in <module>
Please, note the errors differences between first and second try of import.
What is the difference between Python session run from the shell and QGIS
console that could cause the problem?
This problem doesn't exist in the QGIS 32-bit.
Thank you very much for any help!
Radek
[1] http://www.lfd.uci.edu/~gohlke/pythonlibs/
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151006/6bee01b8/attachment-0001.html>
