[Qgis-developer] [GRASS-dev] New GRASS plugin: a test drive
Radim Blazek
radim.blazek at gmail.com
Wed Oct 7 01:38:56 PDT 2015
On Wed, Oct 7, 2015 at 7:01 AM, Maris Nartiss <maris.gis at gmail.com> wrote:
> Radim,
> please provide information on source / target database (DBFs?
> SQLite?); Are permissions set correctly? OS (Windows)?
Normally, you don't need to care about database, GRASS should do
everything for you behind the scenes. By default, the DB is created as
a file inside the mapset, for which you must have write permission by
definition.
Radim
