[Qgis-developer] Geometry Checker contra Topology Checker
Giovanni Manghi
giovanni.manghi at gmail.com
Thu Oct 8 07:19:09 PDT 2015
>>> We also should move the first one to the analysis library, so that the
>>> routines are accessible by plugins and processing framework.... Just
>>> another item on the TODO list!
>> sure, big improvement. better opening a ticket?
>> Giovanni, could you please add tickets for the missing features of the
>> new plugin, and one for the removal of previous plugins?
>> all the best, and thanks.
> I must say that I like more the concept of rules in Topology Checker
> instead of one big dialog used in Geometry Checker. Both from UI and
> programming point of view. It is more flexible and extensible. I am
> curious why a new plugin was started instead of improvement of the old
> one. I don't think that the Topology Checker should be simply removed
> until we have something similar in terms of definition and
> implementation of rules.
Hi, I haven't suggested to remove immediately the topology checker,
but just said that the redundancy with the python geometry checker and
now with the new geometry checker is very puzzling for final users, so
one way or another we should get rid of it (the redundancy).
Moreover the new tool can fix geometries, and this is of course a
must. All the mentioned tools have issues: the topology checker with
reprojected layers and false positives in particular but also the new
geometry checker has a few ones, see for example
http://hub.qgis.org/issues/13535
cheers!
-- G --
