[Qgis-developer] New GRASS plugin: a test drive
Pedro VenĂ¢ncio pedrongvenancio at gmail.com
Thu Oct 8 16:34:33 PDT 2015
Hi again Radim,
> Please start with points and lines. When you digitize a point or line,
> nothing is displayed in canvas? Do you see the elements if you switch
> style to default? Do you see the features in attribute table? Are the
> elements written to the map when you close editing?
>  Note that QGIS can only display features of one type in a layer, if
> you add point layer and digitize a line, it will no show in point
> layer after editing is closed, a new layer with lines must be added to
> canvas.
I'm getting problems with symbology of polygon layers. Please see the
screencast.
https://dl.dropboxusercontent.com/u/5772257/qgis/grass_edit_polygons.ogv
Note also that attribute form pop-up does not show up after each feature
creation on polygons.
After this, if I remove that polygon layer from QGIS canvas/toc, and add
again from browser, then the symbology is ok (but the cat field is gone):
https://dl.dropboxusercontent.com/u/5772257/qgis/grass_edit_polygons_2.ogv
I'm using QGIS master compiled after this commit
https://github.com/qgis/QGIS/commit/e703fc6044e3119c3b59fe9648f7dcf7edc2b714
Thank you very much Radim!
Pedro
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151009/c8458c59/attachment.html>
