[Qgis-developer] New GRASS plugin: a test drive
Radim Blazek radim.blazek at gmail.com
Fri Oct 9 00:11:48 PDT 2015
On Thu, Oct 8, 2015 at 7:00 PM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Il 08/10/2015 18:58, m roy ha scritto:
>> Il 08/10/2015 18.23, Radim Blazek ha scritto:
>>> IMHO: i find it's confusing, and GRASS 7 default database is SQLite,
>>> i think it could be smoother to expose only GRASS Locations and Mapset
>>> being evident that we're dealing with a GRASS Database, but i can live
>>> with that :-)
>>> You are not the first who is confused. Fix would be easy, so I remove
>>> regular dir if it is recognized as GRASS location?
> Hi Radim,
> once you're there, could you please see if it is easy to fix also:
> https://hub.qgis.org/issues/8220 ?
Everybody can do it, I don't prevent others from work on browser.
Radim
