[Qgis-developer] error when compiling with grass7
matteo
matteo.ghetta at gmail.com
Fri Oct 9 03:05:12 PDT 2015
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA256
Hi Jürgen,
no idea why it didn't get built. During the compilation it scan for
all the grass dependencies:
Scanning dependencies of target grassplugin7
[ 78%] Building CXX object
src/plugins/grass/7/CMakeFiles/grassplugin7.dir/__/qgsgrassaddfeature.cp
p.o
src/plugins/grass/7/CMakeFiles/grassplugin7.dir/__/qgsgrasseditrenderer.
cpp.o
src/plugins/grass/7/CMakeFiles/grassplugin7.dir/__/qgsgrassplugin.cpp.o
src/plugins/grass/7/CMakeFiles/grassplugin7.dir/__/qgsgrassselect.cpp.o
src/plugins/grass/7/CMakeFiles/grassplugin7.dir/__/qgsgrasstools.cpp.o
src/plugins/grass/7/CMakeFiles/grassplugin7.dir/__/qgsgrassmapcalc.cpp.o
etc....
and then I get the same error message of above:
[ 80%] Building CXX object
src/plugins/grass/7/CMakeFiles/grassplugin7.dir/__/qtermwidget/moc_qterm
widget.cxx.o
src/plugins/grass/7/CMakeFiles/grassplugin7.dir/qrc_qgsgrass_plugin.cxx.
o
Linking CXX shared module
../../../../output/lib/qgis/plugins/libgrassplugin7.so
/usr/bin/ld: cannot find -lqgisgrass7
collect2: error: ld returned 1 exit status
src/plugins/grass/7/CMakeFiles/grassplugin7.dir/build.make:1942:
recipe for target 'output/lib/qgis/plugins/libgrassplugin7.so' failed
make[2]: *** [output/lib/qgis/plugins/libgrassplugin7.so] Error 1
CMakeFiles/Makefile2:3524: recipe for target
'src/plugins/grass/7/CMakeFiles/grassplugin7.dir/all' failed
make[1]: *** [src/plugins/grass/7/CMakeFiles/grassplugin7.dir/all] Error
2
Makefile:146: recipe for target 'all' failed
make: *** [all] Error 2
that's weird just because the last time I've compiled all went fine..
Thanks
Matteo
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iQEcBAEBCAAGBQJWF5FYAAoJEBy7UYf0gaEODbwH/1LpR9JEd0NnIBuyiyxOlUbF
NWppUyR7l9QB9RzXMVmmbcehYD5hMG7NbdwaDKtP++SpoDLkArMboR++jVXG1Oki
cL0kLOvWIQgs7mr/u23Q2TyJbjTj/QkjWf0La/BSx4/gajJwM5tdCtPALEuls6vO
WMsv8/oco0KgpWP1WooiVpxJlNpXg/4OmCck8yNF3aFotH6a2yfuQPgF0jJIYnNK
BWnyw9wUU6qZX+c9Kgf3qmFIkT8h9Fk2P+6+2QQQg/VCdAw8WN82xDdvVAI6lj1r
JLW/h21RaxkBgHXsEwddA9TA6ap17aaw9zVZq7xqA7+jo/eYd0pW5qzjAHZFl8s=
=VQnr
-----END PGP SIGNATURE-----
