[Qgis-developer] New GRASS plugin: a test drive
Radim Blazek radim.blazek at gmail.com
Mon Oct 12 10:32:28 PDT 2015
On Mon, Oct 12, 2015 at 6:33 PM, m roy <royroge at outlook.com> wrote:
>>> another issue I discovered while testing QGIS digitizer with GRASS vectors
>>> is that there is no difference between node and vertex, in GRASS they have
>>> two different "topological meaning"; as it is now you can't tell
>>> where to connect with a new boundary because of this.
>> I think that the cleanest way to get nodes displayed will be to add
>> first/last vertex marker line symbol in boundaries style, which you
>> can try immediately if you change 'GRASS Edit' style.
> Nice idea, just tried, unfortunately QGIS crashes (on Windows) if i try
> to change line
> boundary to "Marker line";
With 'GRASS Edit' style only? When exactly? When you click Apply on style tab?
Radim
