[Qgis-developer] New GRASS plugin: a test drive
Pedro VenĂ¢ncio
pedrongvenancio at gmail.com
Mon Oct 12 11:07:42 PDT 2015
> > QGIS crashes when you select "Marker line" in symbol layer type right
> away,
> > not only with 'GRASS Edit' style also with default style on a shapefile;
> so
> > i think it's not related to GRASS plugin...
I confirm this seg fault:
Program received signal SIGSEGV, Segmentation fault.
0xb6014f0a in QMetaObject::activate(QObject*, QMetaObject const*, int,
void**)
() from /usr/lib/i386-linux-gnu/libQtCore.so.4
(gdb) bt
#0 0xb6014f0a in QMetaObject::activate(QObject*, QMetaObject const*, int,
void**) () from /usr/lib/i386-linux-gnu/libQtCore.so.4
#1 0xb593fe35 in QComboBox::currentIndexChanged(QString const&) ()
from /usr/lib/i386-linux-gnu/libQtGui.so.4
#2 0xb593fe96 in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4
#3 0xb5940176 in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4
#4 0xb59402c3 in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4
#5 0xb59429fa in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4
#6 0xb60150f7 in QMetaObject::activate(QObject*, QMetaObject const*, int,
#7 0xb5c0a695 in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4
#8 0xb593acf4 in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4
#9 0xb5ffffbe in
QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*)
#10 0xb550c7d1 in QApplicationPrivate::notify_helper(QObject*, QEvent*) ()
#11 0xb5514ea0 in QApplication::notify(QObject*, QEvent*) ()
#12 0xb6a467b3 in QgsApplication::notify (this=0xbf8cbba4,
receiver=0xdbcd598,
event=0xbf8c9a54)
at /home/pedro/qgis/QGIS-master/src/core/qgsapplication.cpp:265
#13 0xb5fffe4a in QCoreApplication::notifyInternal(QObject*, QEvent*) ()
---Type <return> to continue, or q <return> to quit---
#14 0xb5512b53 in QApplicationPrivate::sendMouseEvent(QWidget*,
QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) ()
#15 0xb5596bd0 in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4
#16 0xb5595ef5 in QApplication::x11ProcessEvent(_XEvent*) ()
#17 0xb55c1554 in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4
#18 0xb14111e3 in g_main_context_dispatch ()
from /lib/i386-linux-gnu/libglib-2.0.so.0
#19 0xb1411468 in ?? () from /lib/i386-linux-gnu/libglib-2.0.so.0
#20 0xb1411528 in g_main_context_iteration ()
#21 0xb602f93b in
QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)
#22 0xb55c160e in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4
#23 0xb5ffe823 in
QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from
#24 0xb5ffeb49 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) ()
#25 0xb5a3d081 in QDialog::exec() () from
#26 0xb633127c in
QgsCategorizedSymbolRendererV2Widget::changeCategorizedSymbol
(this=0xd28c168)
at
/home/pedro/qgis/QGIS-master/src/gui/symbology-ng/qgscategorizedsymbolren---Type
dererv2widget.cpp:570
#27 0xb65c480e in QgsCategorizedSymbolRendererV2Widget::qt_static_metacall (
_o=0xd28c168, _c=QMetaObject::InvokeMetaMethod, _id=0, _a=0xbf8ca128)
at
/home/pedro/qgis/QGIS-master/build-master/src/gui/symbology-ng/moc_qgscategorizedsymbolrendererv2widget.cxx:153
#28 0xb60150f7 in QMetaObject::activate(QObject*, QMetaObject const*, int,
#29 0xb5c0926d in QAbstractButton::clicked(bool) ()
#30 0xb5923c21 in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4
#31 0xb5924fa7 in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4
#32 0xb59250ae in QAbstractButton::mouseReleaseEvent(QMouseEvent*) ()
#33 0xb556640a in QWidget::event(QEvent*) ()
#34 0xb59260b2 in QAbstractButton::event(QEvent*) ()
#35 0xb59c0c7c in QPushButton::event(QEvent*) ()
#36 0xb550c7f4 in QApplicationPrivate::notify_helper(QObject*, QEvent*) ()
#37 0xb5514ea0 in QApplication::notify(QObject*, QEvent*) ()
#38 0xb6a467b3 in QgsApplication::notify (this=0xbf8cbba4,
receiver=0xd26b4d0,
event=0xbf8ca614)
#39 0xb5fffe4a in QCoreApplication::notifyInternal(QObject*, QEvent*) ()
#40 0xb5512b53 in QApplicationPrivate::sendMouseEvent(QWidget*,
#41 0xb55967a8 in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4
#42 0xb5595ef5 in QApplication::x11ProcessEvent(_XEvent*) ()
#43 0xb55c1554 in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4
#44 0xb14111e3 in g_main_context_dispatch ()
#45 0xb1411468 in ?? () from /lib/i386-linux-gnu/libglib-2.0.so.0
#46 0xb1411528 in g_main_context_iteration ()
#47 0xb602f95f in
#48 0xb55c160e in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4
#49 0xb5ffe823 in
#50 0xb5ffeb49 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) ()
#51 0xb5a3d081 in QDialog::exec() () from
#52 0xb714e754 in QgisApp::showLayerProperties (this=0x9a85c00,
ml=0xc800260)
at /home/pedro/qgis/QGIS-master/src/app/qgisapp.cpp:10398
#53 0xb7135678 in QgisApp::layerProperties (this=0x9a85c00)
at /home/pedro/qgis/QGIS-master/src/app/qgisapp.cpp:5567
#54 0xb710a8a1 in QgisApp::layerTreeViewDoubleClicked (this=0x9a85c00,
index=...) at /home/pedro/qgis/QGIS-master/src/app/qgisapp.cpp:412
#55 0xb74d9b3e in QgisApp::qt_static_metacall (_o=0x9a85c00,
_c=QMetaObject::InvokeMetaMethod, _id=10, _a=0xbf8cad48)
at /home/pedro/qgis/QGIS-master/build-master/src/app/moc_qgisapp.cxx:628
#56 0xb60150f7 in QMetaObject::activate(QObject*, QMetaObject const*, int,
#57 0xb5a96085 in QAbstractItemView::doubleClicked(QModelIndex const&) ()
#58 0xb5ae379f in QTreeView::mouseDoubleClickEvent(QMouseEvent*) ()
#59 0xb556656b in QWidget::event(QEvent*) ()
#60 0xb596c91c in QFrame::event(QEvent*) ()
#61 0xb59fafd8 in QAbstractScrollArea::viewportEvent(QEvent*) ()
#62 0xb5a9ff6c in QAbstractItemView::viewportEvent(QEvent*) ()
#63 0xb5ae57b6 in QTreeView::viewportEvent(QEvent*) ()
#64 0xb59fb256 in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4
#65 0xb5ffffbe in
#66 0xb550c7d1 in QApplicationPrivate::notify_helper(QObject*, QEvent*) ()
#67 0xb5514ea0 in QApplication::notify(QObject*, QEvent*) ()
#68 0xb6a467b3 in QgsApplication::notify (this=0xbf8cbba4,
receiver=0x9ce29b8,
event=0xbf8cb3f4)
#69 0xb5fffe4a in QCoreApplication::notifyInternal(QObject*, QEvent*) ()
#70 0xb5512b53 in QApplicationPrivate::sendMouseEvent(QWidget*,
#71 0xb55967a8 in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4
#72 0xb5595ef5 in QApplication::x11ProcessEvent(_XEvent*) ()
#73 0xb55c1554 in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4
#74 0xb14111e3 in g_main_context_dispatch ()
#75 0xb1411468 in ?? () from /lib/i386-linux-gnu/libglib-2.0.so.0
#76 0xb1411528 in g_main_context_iteration ()
#77 0xb602f93b in
#78 0xb55c160e in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4
#79 0xb5ffe823 in
#80 0xb5ffeb49 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) ()
#81 0xb60048fe in QCoreApplication::exec() ()
#82 0xb550aa24 in QApplication::exec() ()
#83 0x08050705 in main (argc=1, argv=0xbf8cbe24)
at /home/pedro/qgis/QGIS-master/src/app/main.cpp:1229
(gdb) continue
Continuando.
[Thread 0x94e67b40 (LWP 3582) exited]
[Thread 0xa93a0b40 (LWP 3577) exited]
Program terminated with signal SIGSEGV, Segmentation fault.
The program no longer exists.
It happens with every layer data source when changing 'Symbol layer type',
so not related with GRASS plugin.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151012/635c8622/attachment-0001.html>
