[Qgis-developer] grass plugin: r.contour failing
Radim Blazek radim.blazek at gmail.com
Fri Oct 16 10:39:05 PDT 2015
On Fri, Oct 16, 2015 at 6:21 PM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Il 16/10/2015 16:52, Radim Blazek ha scritto:
>> So it seem to be a problem in r.contour, thus question to grass list.
> indeed. somehow the region is smaller than I expected, sorry for the noise.
> all the best.
It should show warning dialog if a module is using region and input is
outside current region.
There was a bug, fixed now.
Radim
