[Qgis-developer] How should the dissolve tool in Processing work?
Alexandre Neto senhor.neto at gmail.com
Mon Oct 19 05:21:20 PDT 2015
I think this is a bit of feature request, but I would say it should be
possible to have some control over the remaining attributes. Trimming all
attributes seems poor to me, but keeping the attributes with "first
attribute found" without informing the user it's also not good.
Harrissou Santanna mentioned the Dissolve with Stats Plugin. That's the way
ArgGIS does it, you can have stats or even join/concatenate of the
non-dissolved attributes.
Victor Olaya <volayaf at gmail.com> escreveu no dia seg, 19/10/2015 às 12:15:
> Hi Anita
> nice discussion you bring up
> Shouldn't it behave like the ftools dissolve tool currently does?
> 2015-10-19 13:10 GMT+02:00 Anita Graser <anitagraser at gmx.at>:
> > Hi,
> > I'm asking for your input on a discussion concerning the Processing
> dissolve
> > tool here: http://hub.qgis.org/issues/13502
> > How should it ideally work, i.e. how should the attributes of the
> dissolved
> > features be treated? Given the current Processing limitations, how should
> > the options look like?
> > Thanks in advance! Best wishes
> > Anita
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151019/994b215b/attachment-0001.html>
