[Qgis-developer] How should the dissolve tool in Processing work?
Victor Olaya volayaf at gmail.com
Mon Oct 19 23:42:01 PDT 2015
> Do you mean drop fields (as is now but in debate) or keep first value (as it
> used to be before)?
Make the algorithm behave like the one from the mentioned plugin
> How would you enter the value? I could imagine a LineEdit where you input
> e.g. a comma-separated list of fields to keep and another one where you
> input a comma-separated list of the stats to apply? To apply several stats
> on one field you would need multiple entries in LineEdit1?
At first, on a line edit, with a string like
"[field_to_keep],[stat_to_apply], [field_to_keep],[stat_to_apply,
[field_to_keep],[stat_to_apply]..."
Not very intuitive if it's not documented, but will do until the UI is ready
