[Qgis-developer] Possible memory leak in QGIS redraws?
Paulo van Breugel p.vanbreugel at gmail.com
Thu Oct 22 01:33:26 PDT 2015
On 22-10-15 09:35, Nyall Dawson wrote:
> On 21 Oct 2015 6:49 PM, "Nyall Dawson" <nyall.dawson at gmail.com
> <mailto:nyall.dawson at gmail.com>> wrote:
> > On 21 Oct 2015 3:20 PM, "Nyall Dawson" <nyall.dawson at gmail.com
> > > On 9 October 2015 at 01:45, Régis Haubourg
> > > <regis.haubourg at eau-adour-garonne.fr
> <mailto:regis.haubourg at eau-adour-garonne.fr>> wrote:
> > > > Hi all,
> > > > I try to narrow down a production issue here.
> > > > In long sessions with lot's of redraws on complex projects,
> memory seems to
> > > > increase regularly.
> > > > In a more simple environnement with no plugins, just sending
> multiple
> > > > redraws using F5 key triggers it.
> > > > It grows quite fast on 2.6 up to 4Go sometimes, quite slower in
> master and
> > > > 2.10. Every 5-6 redraws, QGIS adds 1Mo of RAM in 2.6, less often
> in recent
> > > > versions.
> > > > If confirmed, and if nothing else is to be blamed (windows?,
> QT?) this is a
> > > > serious issue for enterprise uses, especially if we want to build
> > > > application that run all day long with many canvas redraws.
> > > I've done some more testing, using valgrind and massif. Here's
> what I've found:
> > > - there's a big leak coming from Qt's font database. Fixed in Qt 5.1
> > > (https://bugreports.qt.io/browse/QTBUG-26861). About 50% of the memory
> > > leaked is caused by this one. We could possibly work around it by
> > > having a singleton so we only ever use one QFontDatabase in QGIS, or
> > > just get on with the move to Qt5 and get the proper fix for free. ;)
> > > - I also see a lot of memory used by Python objects. Specifically, a
> > > lot coming from QgsPythonUtilsImpl::evalString and the PyRun_String
> > > call in that function. I don't think these are leaks though (at least,
> > > not within QGIS). But that's the second largest memory allocator I see
> > > reported by massif
> > > - There was a small leak of a GEOS object in labeling... don't think
> > > this would cause too much memory usage though. I'll submit a fix after
> > > giving it some more testing.
> > > - Lastly, the remaining large chunk of allocated memory is used by the
> > > images stored during rendering. I'm 90% sure these are all properly
> > > cleaned, but I still can't throw the niggling suspicion that just
> > > maybe there's some special condition in which these images aren't
> > > properly deleted.
> > > So yeah... no magic fixes to this one unfortunately. (At least, not
> > > until QGIS 3.0!)
> > Actually... Scratch that. Just found some huge leaks in certain
> circumstances. Fixes in progress.
> Try with latest master. It's made a huge difference for me. Exporting
> my most complex atlas (300 pages, with shapeburst, layer effects, some
> pretty hefty dynamic labeling):
> Initially memory usage is about 320mb.
> 2.8: memory usage grows to 1.5 gb
> 2.10: memory usage to about 2 gb
> Master: memory usage grows to 480 mb
Impressive! Will try out a.s.a.p.
> Win! I suspect Qt5 will make another big difference too.
> Nyall
> > Nyall
> > > Nyall
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151022/87c56ba8/attachment.html>
