[Qgis-developer] encoding in custom python functions
Alexandre Neto
senhor.neto at gmail.com
Thu Oct 22 05:30:26 PDT 2015
Ah... I think I now understand what you are saying. You are saying that
expression files are always saved in your system default encoding system.
Sorry for the noise.
Lauri Kajan <lauri.kajan at gmail.com> escreveu no dia qui, 22/10/2015 às
13:25:
> Hi Alexandre,
> The u'ä' works if I tell the file encoding using your snippet
> # -*- coding: utf-8 -*-
> But this works only in qgis and is not a correct way.
> I cannot then debug my function in any IDE cause the file is encoded
> differently than it says.
> -Lauri
> On Thu, Oct 22, 2015 at 1:37 PM, Alexandre Neto <senhor.neto at gmail.com>
> wrote:
>> Have you tried to put the following line in the top of the file?
>> 08:42:
>>> Hi all,
>>> I'm trying to figure out some encoding problems when using custom python
>>> expression functions.
>>> I'm using python functions for defining some label texts. I need use
>>> some special characters like ä and ö.
>>> When a new file is created in function editor the file is encoded in my
>>> system encoding cp1252. At least the ä is coded to 0xe4 if I check that
>>> with hex-editor.
>>> Let the custom function just be
>>> @qgsfunction(args='auto', group='Custom')
>>> def encodingtest(feature, parent):
>>> return 'ä'
>>> This displays on a map like 'ä'
>>> It seems that the file is converted to utf-8 before execution and the ä
>>> is then coded to 0xc3 0xa4. Now QGIS still tries to interpret this as
>>> cp1252 and then displays this as 'ä'.
>>> It doesn't help to define the ä as unicode like u'ä' because QGIS still
>>> sees the ä as 0xc3 0xa4 and think that it is in cp1252.
>>> The only way to resolve this in the code at least that I have found is
>>> to use
>>> return 'ä'.decode('utf-8')
>>> This works on QGIS but the file can't be executed elsewhere (IDE) since
>>> the file is truly in cp1252 and 0xe4 can't be decoded using utf-8.
>>> Does anyone else confirm this and have I understood right the problem?
>>> Should I file a bug report?
>>> Thanks,
>>> -Lauri
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151022/af0b1804/attachment-0001.html>
