[Qgis-developer] [Linux Mint] QGIS Master 3d93237
    Luigi Pirelli
    luipir at gmail.com
    Mon Oct 26 02:32:13 PDT 2015
Hi Mathias
seems related with this your commit about Python3 compatbility
cd0eb05deddc610a1a79c40163504efddfe3da3a
src/python/qgspythonutilsimpl.cpp
-  if ( !PyString_Check( obResult ) )
+  if ( !PyUnicode_Check( obResult ) )
     TRACEBACK_FETCH_ERROR( "getvalue() did not return a string" );
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Elance: https://www.elance.com/s/edit/luigipirelli/
* GitHub: https://github.com/luipir
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 25 October 2015 at 22:06, Luigi Pirelli <luipir at gmail.com> wrote:
> confirmed also ubuntu 15.10 and just pulled the qgis code.
> last log messages was oading the python module:
> src/app/qgisapp.cpp: 7911: (loadPythonSupport) [3ms] load library
> /home/ginetto/PROGRAMMING/QGIS-2.0-master/build/output/lib/qgispython
> (2.13.0)
> regards
> Luigi Pirelli
> * Mastering QGIS:
> On 25 October 2015 at 15:42, João Gaspar <joao.f.r.gaspar at gmail.com> wrote:
>> Hi guys,
>> today after compile and install the master version when i open QGIS Master
>> and he give me this error:
>> Couldn't load PyQGIS.
>> Python support will be disabled.
>> Python version:
>> 2.7.6 (default, Jun 22 2015, 18:01:27)
>> [GCC 4.8.2]
>> QGIS version:
>> 2.13.0-Master 'Master', 3d93237
>> Python path:
>> ['/home/joao/apps/share/qgis/python', u'/home/joao/.qgis2/python',
>> u'/home/joao/.qgis2/python/plugins',
>> '/home/joao/apps/share/qgis/python/plugins', '/usr/lib/python2.7',
>> '/usr/lib/python2.7/plat-x86_64-linux-gnu', '/usr/lib/python2.7/lib-tk',
>> '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload',
>> '/usr/local/lib/python2.7/dist-packages',
>> '/usr/lib/python2.7/dist-packages',
>> '/usr/lib/python2.7/dist-packages/PILcompat',
>> '/usr/lib/python2.7/dist-packages/gst-0.10',
>> '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7',
>> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode']
>> What can be the problem?
>> Regards
>> João
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
