[Qgis-developer] use ogr2ogr in a plugin
    geodrinx at gmail.com
    Wed Oct 28 09:58:03 PDT 2015
Hi Denis,
> The idea is to connect to a Postgres DB and writes content of tables
> into shapefiles. One way would be to load the tables in QGIS and write
> content manually, but a single ogr2ogr would be quite straightforward.
You need to write a SHP directly ?  Do you need something like a batch, for mass production purposes ?
Why don't you use simply the standard Qgis postgis connection ?
You can "add" a PostGIS connection and open a table.
It is not sufficient, this ?
Explain it better.
A presto
Roberto
> Thanks a lot for any lead,
> Denis
> Qgis-developer mailing list
