[Qgis-developer] How to access the QgsVisibilityPresetCollection() in pyqgis
Nyall Dawson
nyall.dawson at gmail.com
Thu Oct 29 05:55:25 PDT 2015
On 29 October 2015 at 23:31, Alexandre Neto <senhor.neto at gmail.com> wrote:
> Is it possible to access to presets in a project using PyQgis? I found
> QgsVisibilityPresetCollection() in QGIS API, but I can't seem to find how to
> access the current one used by the active project.
You access it through the project instance (in 2.12 at least... it
wasn't accessible to PyQGIS in previous versions). See
http://qgis.org/api/classQgsProject.html#a33240f824d62c40d56ee569f6b0ac2a5
Nyall
> My plans were to create a plugin that allows to manage all the projec
> presets. Things like update or rename a preset (without the need to remove
> the current ones), and also return a list of presets to be used in Map
> Composition.
> Thanks
> Alexandre Neto
> Qgis-developer mailing list
