[Qgis-developer] no more map ?
Matthias Kuhn matthias at opengis.ch
Mon Sep 7 12:23:29 PDT 2015
There were some changes in that area of the code in the last 2 weeks, so
if it works with current master I guess it's ok to assume it's fixed
until somebody complains.
Matthias
On 09/07/2015 09:12 PM, Sandro Santilli wrote:
> On Mon, Sep 07, 2015 at 08:00:44PM +0200, Salvatore Larosa wrote:
>> Il 07/Set/2015 19:44, "Sandro Santilli" <strk at keybit.net> ha scritto:
>>> I'm running qgis from master after a long time and facing
>>> a gui that does not show the map:
>>>  http://strk.keybit.net/tmp/qgis-nomap.png
>> How you done to load 2 layers and keep up the welcome page?
> Right, that's the problem. I used "Add PostGIS Layer", selected
> those two tables, and hit "Load". The commit id can be seen in
> the titlebar. I hadn't tried to reproduce with that same commit,
> and I could not reproduce (on first try) with current master.
> Possible race condition ?
> --strk;
> Qgis-developer mailing list
