[Qgis-developer] trouble when compiling QGIS (libgeos)
sebastic sebastic at xs4all.nl
Thu Sep 10 04:27:45 PDT 2015
On 2015-09-10 13:06, Matteo Ghetta wrote:
> make[2]: *** No rule to make target '/usr/lib/libgeos_c.so', needed by
> 'output/lib/libqgis_core.so.2.11.0'.  Stop.
Assuming your using Debian/Ubuntu, since GEOS 3.5.0 the geos libraries
have moved to the Multi-Arch library paths (/usr/lib/x86_64-linux-gnu/
on amd64).
It looks like you're specifying GEOS_LIBRARY manually, FindGEOS supports
both the traditional and Multi-Arch library paths.
Kind Regards,
Bas
