[Qgis-developer] QGIS Server does not release files after each request - OGROpenShared instead of OGROpen ?
kimaidou
kimaidou at gmail.com
Fri Sep 11 00:39:59 PDT 2015
Hi all
We are trying to use QGIS Server with nginx / supervisor instead of
classical Apache / mod_fcgid.
We have seen that for each server request, such as a GetMap responding an
image rendered from a single Shapefile (or Tiff, of whatever), QGIS Server
opens a new access to the file.
Exemple number found via the lsof command, after some requests
lsof /tmp/someShapefile.shp | wc -l
126
which means here 126 requests has been processed by QGIS Server, but the
access to Shapfile has never been released. Each requests leads to a new
file handler.
Imagine a project with several layers, and a web map with many users /
requests --> this lead rapidly to many opening of the same files open for
nothing, and can cause issues.
In Apache configuration, this was not sensible, as mod_fcgid and Apache
kill QGIS Server worker after N completed requests, and it seems the ulimit
used is the system limit.
In our configuration, supervisor has by default a ulimit of 1024 files
opened. This limit is vers fast reached ( 1024 requests only ). We could
tune this configuration, but it seems to walk aournd the issue without
solving its origin.
We have 2 ways of dealing with it :
* Make sure QGIS Server does not open a data file each time a request needs
it --> we will investigate if the cache is well used
* We could also use GDALOpenShared instead of GDALOpen , and OGROpenShared
instead of OGROpen in QGIS provider code:
GDALOpenShared :
http://www.gdal.org/gdal_8h.html#a46a02c21047d78f88f8abb1ff6b14ae2
OGROpen in QGIS :
https://github.com/qgis/QGIS/search?utf8=%E2%9C%93&q=ogropen&type=Code
Any idea, comment appreciated !
Regards,
Michaël
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150911/d01cd8e0/attachment.html>
