[Qgis-developer] problem with master compilation (GRASS issue)
Martin Landa
landa.martin at gmail.com
Fri Sep 11 09:55:54 PDT 2015
Hi all,
I recently tried to compile QGIS master.
$ make install
failed with
CMake Error at /home/landa/src/qgis/build/python/plugins/fTools/cmake_install.cmake:36
(FILE):
file INSTALL cannot find
"/home/landa/src/qgis/build/python/plugins/fTools/resources_rc.py".
Call Stack (most recent call first):
/home/landa/src/qgis/build/python/plugins/cmake_install.cmake:37 (INCLUDE)
/home/landa/src/qgis/build/python/cmake_install.cmake:140 (INCLUDE)
cmake_install.cmake:61 (INCLUDE)
When I try to launch QGIS it simply crash after splash screen
src/core/qgsproviderregistry.cpp: 214: (QgsProviderRegistry) [1ms]
Checking /usr/local/lib/qgis/plugins/libgdalprovider.so: ...loaded ok
(66 file filters)
src/core/qgsproviderregistry.cpp: 131: (QgsProviderRegistry) [1ms]
Checking /usr/local/lib/qgis/plugins/libgeorefplugin.so: ...invalid
(has type method)
src/core/qgsproviderregistry.cpp: 131: (QgsProviderRegistry) [0ms]
Checking /usr/local/lib/qgis/plugins/libgpsimporterplugin.so:
...invalid (has type method)
src/core/qgsproviderregistry.cpp: 131: (QgsProviderRegistry) [5ms]
Checking /usr/local/lib/qgis/plugins/libgrassplugin7.so: ...invalid
(has type method)
src/providers/grass/qgsgrass.cpp: 305: (init) [1ms] do init
src/providers/grass/qgsgrass.cpp: 682: (error_routine) [0ms]
error_routine (fatal = 1): Module built against version $Revision:
64733 $ but trying to use version $Revision: 64732 $. You need to
rebuild GRASS GIS or untangle multiple installations.
src/providers/grass/qgsgrass.cpp: 688: (error_routine) [0ms] fatal -> longjmp
src/core/layertree/qgslayertreeregistrybridge.cpp: 78:
(layersWillBeRemoved) [0ms] 0 layers will be removed, enabled:1
which points to GRASS support (error message comes from GRASS). Anyway
QGIS should not crash at this point. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
