[Qgis-developer] problem with master compilation (GRASS issue)
kimaidou
kimaidou at gmail.com
Tue Sep 15 04:19:27 PDT 2015
Hi all,
I manage to build QGIS after installing manually the dependencies written
in [1] for trusty
apt-get install bison cmake doxygen flex git graphviz grass-dev
libexpat1-dev libfcgi-dev libgdal-dev libgeos-dev libgsl0-dev
libopenscenegraph-dev libosgearth-dev libpq-dev libproj-dev
libqscintilla2-dev libqt4-dev libqt4-opengl-dev libqt4-sql-sqlite
libqtwebkit-dev libqwt5-qt4-dev libspatialindex-dev libspatialite-dev
libsqlite3-dev lighttpd locales pkg-config poppler-utils pyqt4-dev-tools
python-all python-all-dev python-pyspatialite python-qscintilla2 python-qt4
python-qt4-dev python-sip python-sip-dev qt4-doc-html spawn-fcgi txt2tags
xauth xfonts-100dpi xfonts-75dpi xfonts-base xfonts-scalable xvfb
cmake-curses-gui
[1] https://github.com/qgis/QGIS/blob/master/INSTALL#L185
2015-09-15 12:32 GMT+02:00 kimaidou <kimaidou at gmail.com>:
> Hi,
> I would like to build QGIS 2.10 ( branch release-2_10 ) under Ubuntu
> 14.04, so I use the qgis official repository, and then
> apt-get build-dep qgis
> I get a error about missing grass-dev dependencies . Has anyone found a
> way around ?
> Thanks
> Michaël
> 2015-09-12 13:19 GMT+02:00 Martin Landa <landa.martin at gmail.com>:
>> Hi,
>> 2015-09-12 9:10 GMT+02:00 Radim Blazek <radim.blazek at gmail.com>:
>> >> which points to GRASS support (error message comes from GRASS). Anyway
>> >> QGIS should not crash at this point. Martin
>> > You are right, fixed in 95e9ade.
>> thanks, Martin
>> Martin Landa
>> http://geo.fsv.cvut.cz/gwiki/Landa
>> http://gismentors.cz/mentors/landa
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150915/9f95c44f/attachment-0001.html>
