[Qgis-developer] SVG fill broken?
    Andreas Neumann
    a.neumann at carto.net
    Tue Sep 15 04:57:32 PDT 2015
but have you selected a SVG symbol in the list? Your screenshot does not
show a selected symbol. Sorry to insist on that ;-)
The submenu "Line" is normal. It was always there in conjunction with
SVG fills, so you can also set a stroke around the polygons. It has been
like this for many versions. Nothing changed there for a while.
Andreas
On 15.09.2015 13:37, Paolo Cavallini wrote:
> Il 15/09/2015 09:30, Andreas Neumann ha scritto:
>> Can you try to select a file and see how it behaves?
> tried, same thing. The strange issue is the submenu "Line".
>> Is this a project migrated from an older version?
> not, a fresh one.
> thanks.
