[Qgis-developer] QGIS Server : layer ordre from group
Andreas Neumann
a.neumann at carto.net
Tue Sep 15 08:26:12 PDT 2015
Hi René-Luc,
Thank you for your reply!
Will it change the order in the output of GetCapabilities and
GetProjectSettings responses?
You are right that we are sending leaf layers, no groups, in QGIS web
client.
Anyway - I will test and see if I'll need to change QGIS Web Client or not.
Andreas
On 15.09.2015 17:17, René-Luc Dhont wrote:
> Hi Andreas and devs,
> My fixe does not affect the layer order fixed by the WMS LAYERS
> parameters.
> For exemple QGIS Web Client manage the layer order by building the WMS
> LAYERS parameters with all the layers and without groups. QGSI Web
> Client is not concerned by this fixe.
> In Lizmap, user can specify Group as layer, which means that the group
> name is used in the WMS LAYERS parameter. We used it to reduce the
> number of names in the WMS LAYERS parameter, to have 3 rendering based
> on scale in one web client layer, to have based layer, etc. It is not
> a so old issue, probably introduce with the new layer tree.
> I just fix it because the rendering was not in the same order as in
> the Desktop QGIS.
> René-Luc
> Le 15/09/2015 17:14, Andreas Neumann a écrit :
>> Hi René-Luc,
>> Thank you for the patch and the notice - do you know since when this
>> bug was present. Probably since ages?
>> This change will basically mean that all QGIS Web Client users will
>> have to patch their client at the same time they upgrade their server.
>> I am not against this change - I am just thinking about the
>> consequences. I think we reversed rendering order on the client. If
>> we don't communicate this properly - a lot of QGIS server/client
>> users will run into this issue and will complain.
>> Andreas
>> On 15.09.2015 16:50, René-Luc Dhont wrote:
>>> Hi devs and QGIS Server user,
>>> I just fixed an issue in QGIS server and backport it to release-2_10
>>> and release-2_8.
>>> https://github.com/qgis/QGIS/commit/8948721991bf321fb7eb2da259790624183f619d
>>> https://github.com/qgis/QGIS/commit/ae906b5eca9f99d7e4bd4e29e3b1bc4b49122be2
>>> https://github.com/qgis/QGIS/commit/977d17751b9c05da1f09ed40d1cf27a97db5f534
>>> If custom order is not enabled and a group is requested, layers was
>>> added in the DOM element order. The default rendering order is the
>>> reverse. To fix this issue, QgsWMSProjectParser::addLayersFromGroup
>>> has to read group element children from end (bottom) to start (top).
>>> If you use QGIS server, I invite you to update your build.
>>> Regards,
>>> René-Luc
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
