[Qgis-developer] plugin maintenance
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Thu Sep 17 01:19:47 PDT 2015
Hi again,
Could please someone of the core devs have a look at # 11901.
According to the bug report, it appeared and disappeared although I did not make any changes to the plugin code. Actually, the plugin worked nicely for almost a year or so before the bug was reported the first time.
Furthermore, the issue seems to pop-up also with other plugins, according to bug reporter.
I am open for the possibility that the issue is due to this particular plugin, but then I would need help to identify what actually the reason is and where to start fixing it... Possibly GDAL related, as this was reported for Mac (which I have not available...).
Kind regards,
Stefan
-----Original Message-----
From: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Paolo Cavallini
Sent: 10. september 2015 18:56
To: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] plugin maintenance
Il 10/09/2015 10:44, Blumentrath, Stefan ha scritto:
> Recently, I updated the GarminCustomMap plugin which I developed a few
> years ago, because users reported that it crashes QGIS.
> Unfortunately, the bug reports (the plugin uses the QGIS bug tracker
> system and repository) never were forwarded to me, so I noticed them
> only with a significant delay...
> So I was wondering if it is preferred that plugin authors use their
> own versioning and bug tracking solution (github in my case)?
IMHO using only GitHub is the simplest option, and it works well enough.
Of course, I do not like it being proprietary software, but since QGIS code is already there, I think we can't complain.
> Furthermore, the plugin worked nicely with QGIS 2.0 to 2.4. While
> problems were reported for 2.6 and later. I did not change the
> plugin-code in that period, so issues must have been introduced by
> external changes (likely in GDAL/OGR and their windows packages). I
> see that it is impossible to prevent such issues, as plugins are by
> nature not core. But how should plugin authors deal with that? Simply
> send bug reports back to QGIS (in my case it came from there...)?
Yes, I think that's the correct approach.
Thanks for the report.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
